Mach Discussion => General Mach Discussion => Topic started by: fyshious on April 12, 2021, 06:43:13 AM
Title: PWM laser connections
Post by: fyshious on April 12, 2021, 06:43:13 AM
I have had a diode laser running on my CNC for a while now but can only operate it at 100% so I now want to get the PWM working.
I use a Warp9 ESS connected to a 5 axis BOB via port 1 and have pin 17 connected to the PWM connection on the laser for M10/M11 control. Works well.
I built Tweakie's little NAND trigger unit and connected it all up as below and followed the spindle/laser setup in the Warp9 install manual.
I have tried playing with various M10Pxx/M11Pxx and S********* commands but pin 1 will always stay low (0 volts).
I am either missing or not understanding something here and hoping someone can help please.
Title: Re: PWM laser connections
Post by: fyshious on April 12, 2021, 06:45:19 AM
The rest of the attachments
Post by: Tweakie.CNC on April 13, 2021, 12:13:45 AM
Hi Fyshious,
With the Warp9 ESS & Mach3 the PWM signal can be gated with the M11/M10 switching signal within software onboard the ESS – my little NAND gate circuit is not required.
If you follow Warp9’s Laser setup instructions here, you should be good to go.
https://www.warp9td.com/index.php/gettingstarted/setting-up-the-smoothstepper-and-mach#Laser
Post by: fyshious on April 13, 2021, 05:14:52 AM
Hi Tweakie. Thanks for that.
Followed the Warp9 Laser install to the letter but didn't work.
Found that , for some reason, my system only recognises Port 2 for the M10/M11 commands even though the BOB is plugged into port 1 on the ESS.
Changed M11P1 to M11P2 and away it went.
Thanks again for your valuable time and assistance
Doug
Post by: TPS on April 13, 2021, 05:21:34 AM
 M11P1 does not mean port1 it means Output 1
Post by: fyshious on April 13, 2021, 05:34:01 AM
OK. That shows my lack of knowledge  :-[
But I'm learning
I will play with the outputs again
Post by: TPS on April 13, 2021, 05:41:06 AM
in your case M11P2 it means Output 2 witch you have configured in ports&pins to port 1 pin 17.
Post by: fyshious on April 13, 2021, 07:30:11 AM
