Mach Discussion => Mach4 General Discussion => Topic started by: WEBSTERDOUGLASMICHAEL on March 30, 2021, 08:16:24 PM
I'm using mach 4 with the pmdx-411 smartbob. Everything was working fine until today and every time I try to jog i get this error.
PMDX: DEVICE ERROR 'SYSTEM ERROR(7): Motion Underrun'
I also realized it was giving an error at startup
PMDX: Communication status 'Sync'd to Device'
Lua: Error occurred while opening file
cannot open C:\Mach4Hobby\Profiles\PMDXMILL\Macros\mcLua.mcc: No such file or directory
Im not sure what to do. Any help would be greatly appreciated
Disable the motion controller plugin for now.
Remove it from the directory all together.
Then put the attached file into the "Macros" folder inside your MACH4 directory.
MACH4 Hobby > desired Profile > Macros
Then start the profile again and let me know what happens.
Make sure to select Simulation mode again under motion controller selection.
