G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Jamwelds on March 06, 2021, 11:28:07 PM
I cannot get g code to load from sheetcam. Files loaded fine until I restarted Mach3, then me jog speed was reduced by approximately 60%, and codes would no longer load.
post your g-code and we will see
N0010 File Name: Acadia Column Base Plat 16 in 2 .tap
N0020 Post Processor: Mach3 THC With scriber (Edited)
N0030 Date 3/6/2021
N0040 G20 Units: Inches
N0050 F1
N0060 G53 G90 G40
NOO70 Part: Acadia Column Base Plate 16in 2
NOO80 G00 XO.0000 Y0.0000
N0090 M04 M30
That code has never run on Mach3 or any other system. The format is all wrong :-
N0010 File Name: Acadia Column Base Plat 16 in 2 .tap - No brackets
N0020 Post Processor: Mach3 THC With scriber (Edited) - No brackets
N0030 Date 3/6/2021 - No brackets
N0040 G20 Units: Inches - No brackets after G20
N0050 F1
N0060 G53 G90 G40
NOO70 Part: Acadia Column Base Plate 16in 2 - No brackets and 'OO' instead of '00'
NOO80 G00 XO.0000 Y0.0000 - 'OO' instead of '00' and 'XO.0000'
N0090 M04 M30
