Mach Discussion => Mach4 General Discussion => Topic started by: KatzYaakov on February 02, 2021, 04:15:56 AM
the last tab in mach config its toolpath
but on pdf no any coment about this
when i mark it its help with large file that mach crash less
what is the meaning of this check box?
VBO stands for Vertex Buffer Object, this is where the vectors are saved on your graphics cards memory. When you change to not using VBO’s your shifting the graphics memory to your ram. The best thing to do with MASSIVE files is not not show the path and simply run the commands as they come. On die mold machines they don’t show toolpaths for this reason. We may need to tweak things to make this work .. or figure out what your doing and see if there is a better way that will require less memory.
