Mach Discussion => Mach4 General Discussion => Topic started by: rbmgf7 on January 26, 2021, 08:14:19 PM
Title: Any reason not to use Joytokey for Xbox controller?
Post by: rbmgf7 on January 26, 2021, 08:14:19 PM
Only found a couple threads where JoytoKey was mentioned as a way to use an Xbox controller. I installed it and it works great but is there a concern? Figure $7 is a deal to a quick and easy way to use a controller.
It's on my plasma table. Any way to get functions like starting the torch as a keyboard function? All I have are moves.
Title: Re: Any reason not to use Joytokey for Xbox controller?
Post by: Brian Barker on January 27, 2021, 01:11:24 PM
You should check out my plugin that I did ... You can even use it as a mouse in windows! Mapping to toggle functions is easy with the one that I have. I am going to pin it the the top of this section
