Mach Discussion => General Mach Discussion => Topic started by: DICKEYBIRD on January 25, 2021, 06:29:02 AM
Title: Home/limits on same switch setup help.
Post by: DICKEYBIRD on January 25, 2021, 06:29:02 AM
Been away from things for a while and can't get this to work.  I have 3 single switches at the positive extents of XYZ travel and want to use them as both home & limits along with soft limits.
I should be able to start Mach3, press Reset, press "Ref all home" and each axis moves until it bounces off its switch, right?  I've missed something silly in the setup somewhere.  Can one of you Gurus take a look at my .xml please?
edit: Oh yeah, all switches are NC and wired in series.
Title: Re: Home/limits on same switch setup help.
Post by: TPS on January 25, 2021, 08:41:49 AM
you have to set the Enabled for each Input in Config->Ports&Pins-Input signals
Post by: DICKEYBIRD on January 25, 2021, 09:19:17 AM
Ouch! (Dope slapping myself) thanks! :-[
Post by: DICKEYBIRD on January 25, 2021, 12:24:46 PM
Thanks TPS, it all works perfectly now. :)
