Mach Discussion => Mach3 under Vista => Topic started by: awat70 on January 24, 2021, 07:10:37 PM
Title: Mach 3 G-code
Post by: awat70 on January 24, 2021, 07:10:37 PM
Hello everybody.  I have Mach 3 installed on my laptop running windows 7.  I am using a sainsmart 3018 MX3  When I try to load a G-code into Mach 3, it can not find a G-code file or recognize one.  Does anyone have any suggestions to what I am doing wrong?.
Thanks in advance
Title: Re: Mach 3 G-code
Post by: Tweakie.CNC on January 25, 2021, 12:21:58 AM
Can you perhaps explain that a little more ?
Is it a file extention problem ?
Post by: awat70 on January 25, 2021, 04:37:32 PM
Thanks for the reply,
I have Mach 3 running and zeroed my cnc.  Next I click load G code.  The file that I want to load is on my desk top, but when I look at my desk top files in Mach 3, the file is not there. Also, the G-code on the cd that came with the cnc does not show up either.  If I look to see what is on the disc outside of Mach 3, the files are there also.  They do not show up when I try to open them in Mach 3.  I hope this explanation is clear.
Post by: Tweakie.CNC on January 26, 2021, 12:13:01 AM
It looks like you are describing a file extention issue. When loading Gcode files select Files of Type  All Files(*.*) then all files will be visable.
Post by: awat70 on January 26, 2021, 11:52:07 AM
Thank you very much.  That was the problem.  As soon as I changed it to all, all the files were there and loaded into mach 3.
Thank you for all your help.
