Mach Discussion => Brains Development => Topic started by: dafunkdawg on January 10, 2021, 09:52:00 PM
Title: Help with time delay output
Post by: dafunkdawg on January 10, 2021, 09:52:00 PM
I am retrofitting a machine for a friend with pmdx-126  driving the original parker xl25 drivers. The machine has a z brake which I have relay controlled via output 4. My problem is when I enable the machine the z brake releases instantly and the stepper drivers take maybe .5 sec to power up and lock the motor. The z axis drops slightly due to this delay. I am trying to create a brain that will delay the output 4 brake  release for 1 sec. I tried --- output enable 1 ---- timer  ----- output 4. I seem to be a little confused by the timer config. I initially tried A - delay trigger to .5 and B pulse time to 1 sec. The relay just pulses on and off.  Any help would be greatly appreciated
Title: Re: Help with time delay output
Post by: TPS on January 11, 2021, 12:25:05 AM
attached a small sample, witch should do it
Post by: dafunkdawg on January 11, 2021, 11:39:55 PM
Thank you TPS - I will try it out in the morning
