Mach Discussion => General Mach Discussion => Topic started by: kentdesautel on April 06, 2006, 10:04:27 AM
I am using Mach 3 and I am having problems sometimes after completing running a G-Code sequence the mill will not go back to the proper Home position...... the Y-Axis will normally be off.
In other words instead of going back to the home position it will be off roughly 1/4 inch.
The problem always seems to be with the Y-Axis
The Position on the screen shows "0" for all of the X-Y-Z Axis's for both the Machine and Tool postions.... but the Y-Axis will not be at the correct location.
Here is a sample set of code which this occurred:
G40 M6 T1
M7
G0 X2.302 Y0.919 Z0.1
G1 Z-0.01 F1
X2.327 Y0.919 Z-0.01 F2
Y1.081
X2.302
Y0.919
Y0.894
X2.351
Y1.106
X2.278
Y0.894
-------------- Lines removed to shorten post --------------
X0.673
G0 Z0.1
Y0.919
G1 Z-0.22 F1
X0.698 Y0.919 Z-0.22 F2
Y1.081
X0.673
Y0.919
Y0.894
X0.722
Y1.106
X0.649
Y0.894
X0.673
Y0.869
X0.747
Y1.131
X0.624
Y0.869
X0.673
Y0.844
X0.772
Y1.155
X0.599
Y0.844
X0.673
G0 Z0.1
X0 Y0
M02
Why don't you turn down the Accel for the y axis a bit and see if that helps.
