Mach Discussion => General Mach Discussion => Topic started by: HOOTIEDOGG on January 03, 2021, 05:46:55 PM
Title: Wondering if anyone can help with a problem
Post by: HOOTIEDOGG on January 03, 2021, 05:46:55 PM
Hi all thanks for letting me join this group.
I'm having a problem with a part I'm trying to cut, when it does the first depth of the profile cuts its good the second depth cut it gets off in the z positive direction and every cut is off by the same amount it also seems that my machine coordinates gets off each cut it makes.
I would appreciate any help I can get.
Thanks so much.
Mike
Title: Re: Wondering if anyone can help with a problem
Post by: stevehuck on January 03, 2021, 06:15:01 PM
First thing that comes to mind is maybe the machine is binding up or hitting something. I have had it happen to me a few times where I will make a few cuts and the Z axis gets to its bottom hard stop and the cutter wont go any deeper so the stepper loses steps and nothing good happens from there.
Post by: Ulstermanone on January 06, 2021, 08:24:40 AM
Did you run calibration for that Axis ?-many Videos online to preform this
After that check back lash for the Axis ?
