Mach Discussion => VB and the development of wizards => Topic started by: birillo1959 on December 20, 2020, 03:53:27 AM
Buongirno
I use this macro for full center piece (modified to my needs by TPS) I would like to make some changes:
add double tap as it is not in my capacity.
I thank those who can help me.
Rem VBScript To center probe outside diameter Metric Version
Speak (" psizionarsi CINQUE millimetri sopra il pezzo") 'Avviso Vocale
response = MsgBox (" 5 mm SOPRA IL PEZZO")
Begin Dialog ButtonSample 250,200,120,60," CENTRO PEZZO PIENO ? "
OKButton 12,20,40,14
CancelButton 68,20,40,14
End Dialog
Dim Dlg2 As ButtonSample
Button = Dialog (Dlg2)
If Button = 0 Then
MsgBox "CENTRO PEZZO CANCELLATO !"
Speak (" CENTRO PEZZO CANCELLATO") 'Avviso Vocale
Exit Sub
End If
Sleep (1000) ' pausa di 1 secondi
Speak (" CONFERMARE centro pezzo pieno") 'Avviso Vocale
Message "INIZIO CENTRO PEZZO PIENO"
response = MsgBox ("CONFERMARE CENTRO PEZZO PIENO")
Message "**** zero assi ****"
DoOEMButton (1008) 'zero X
DoOEMButton (1009) 'zero Y
DoOEMButton (1010) 'zero Z
Sleep (2000) ' pausa di 1 secondi
Speak ("ZERO assi completato") 'Avviso Vocale
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(1000) 'gets the current tool diameter
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
Call ProbeGrounded()
Exit Sub
Else
XCurrent = GetDro(0)
YCurrent = GetDro(1)
OutsideDiameter = GetUserDRO(1152)
Code "G4 P1" 'Pause 1 second to give time to position probe plate
While IsMoving ()
Wend
Call SetDro (0,0.000)
While IsMoving ()
Wend
Call SetDro (1,0.000)
Code "F50" 'slow feed rate to 100mm/sec
Code "G90 G0 X" &XNew + OutsideDiameter * .6
Code "G91 G0 Z-10"
Rem Probe Left
XNew = Xcurrent - 75
Code "G31 X" &XNew
While IsMoving() 'wait for the move to finish
Wend
XPos1 = GetVar(2000) 'get the probe touch location
Code "G91 G0 X2"
Code "G91 G0 Z10"
Code "G90 G0 X" &XCurrent 'rapid move back to start point
Code "G91 G0 X" &XCurrent - OutsideDiameter * .6
Code "G91 G0 Z-10"
Rem Probe Right
XNew = XCurrent + 75 'probe 75mm to right
Code "G31 X" &XNew
While IsMoving()
Wend
XPos2 = GetVar(2000)
Code "G91 G0 X-2"
Code "G91 G0 Z10"
XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
Code "G90 G0 X" &XCenter 'rapid move to the x center location
While IsMoving ()
Wend
Code "G4 P0.25"
Code "G90 G0 Y" &YNew - OutsideDiameter * .6
Code "G91 G0 Z-10"
Rem Probe up
YNew = YCurrent + 75
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos1 = GetVar(2001)
Code "G91 G0 Y-2"
Code "G91 G0 Z10"
Code "G90 G0 Y" &YCurrent
Code "G91 G0 Y" &YCurrent + OutsideDiameter * .6
Code "G91 G0 Z-10"
Rem Probe down
YNew = YCurrent - 75
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos2 = GetVar(2001)
Code "G91 G0 Y2"
Code "G91 G0 Z10"
YCenter = (YPos1 + YPos2) / 2
Rem move To the center
Code "G90 G0 Y" &YCenter
While IsMoving ()
Wend
While IsMoving ()
Wend
Call SetUserDro (1152,YPos2 - YPos1 - CurrentToolDiameter)
Code "G4 P0.25"
Code "F" &CurrentFeed 'restore starting feed rate
Call ReturnG90G91State()
Exit Sub
End If
what do you mean with double tap?
Good morning
by double touch I mean that once the probe touches the piece it moves backwards by 2mm and then slowly touches the piece for the second time obtaining the most accurate measurement
I hope I explained myself (translated with google)
thanks TPS
End Dialog
If Button = 0 Then
Exit Sub
End If
Exit Sub
Else
While IsMoving ()
Wend
While IsMoving ()
Wend
Code "G91 G0 Z-10"
Rem Probe Left
Code "G31 X" &XNew
Wend
Code "G91 G0 X2 F10"
Wend
Code "G31 X" &XNew
Wend
Code "G91 G0 X2 F50"
Code "G91 G0 Z10"
Code "G91 G0 Z-10"
Rem Probe Right
Code "G31 X" &XNew
While IsMoving()
Wend
Code "G91 G0 X-2 F10"
Wend
Code "G31 X" &XNew
Wend
Code "G91 G0 X-2 F50"
Code "G91 G0 Z10"
While IsMoving ()
Wend
Code "G4 P0.25"
Code "G91 G0 Z-10"
Rem Probe up
Code "G31 Y" &YNew
While IsMoving()
Wend
Code "G91 G0 Y-2 F10"
Wend
Code "G31 Y" &YNew
Wend
Code "G91 G0 Y-2 F50"
Code "G91 G0 Z10"
Code "G91 G0 Z-10"
Rem Probe down
Code "G31 Y" &YNew
While IsMoving()
Wend
Code "G91 G0 Y2 F10"
Wend
Code "G31 Y" &YNew
Wend
Code "G91 G0 Y2 F50"
Code "G91 G0 Z10"
While IsMoving ()
Wend
While IsMoving ()
Wend
Code "G4 P0.25"
Exit Sub
End If
the modification works great !!!
if I don't ask too much is it possible to separate axes?
I mean having 2 macros, one for x axis (always x for full)
one for y axis (always for full)
I sincerely thank you for the help given
X-Axis
Rem VBScript To center probe X-Axis
End Dialog
If Button = 0 Then
Exit Sub
End If
Exit Sub
Else
While IsMoving ()
Wend
While IsMoving ()
Wend
Code "G91 G0 Z-10"
Rem Probe Left
Code "G31 X" &XNew
Wend
Wend
Code "G31 X" &XNew
Wend
Code "G91 G0 Z10"
Code "G91 G0 Z-10"
Rem Probe Right
Code "G31 X" &XNew
While IsMoving()
Wend
Wend
Code "G31 X" &XNew
Wend
Code "G91 G0 Z10"
While IsMoving ()
Wend
Code "G4 P0.25"
Exit Sub
End If
Y-Axis
Rem VBScript To center probe Y-Axis
End Dialog
If Button = 0 Then
Exit Sub
End If
Exit Sub
Else
While IsMoving ()
Wend
While IsMoving ()
Wend
Code "G91 G0 Z-10"
Rem Probe up
Code "G31 Y" &YNew
While IsMoving()
Wend
Wend
Code "G31 Y" &YNew
Wend
Code "G91 G0 Z10"
Code "G91 G0 Z-10"
Rem Probe down
Code "G31 Y" &YNew
While IsMoving()
Wend
Wend
Code "G31 Y" &YNew
Wend
Code "G91 G0 Z10"
While IsMoving ()
Wend
While IsMoving ()
Wend
Code "G4 P0.25"
Exit Sub
End If
the macros work well the only thing that in the measurement is 1mm less, I mean the piece is 80mm in the 79mm dro
I tried to insert +1 in the line:
Call SetUserDro (1152, YPos2 - YPos1 - CurrentToolDiameter)
modified
Call SetUserDro (1152, YPos2 - YPos1 - CurrentToolDiameter +1)
and that's okay but I don't know if it's a legitimate thing!!
