Mach Discussion => Mach4 General Discussion => Topic started by: Tony Bullard on December 17, 2020, 08:51:44 AM
Title: G31 not working in screen function
Post by: Tony Bullard on December 17, 2020, 08:51:44 AM
Mach4Lathe: When G31 G01 X-.20 F5 is called from the MDI the machine stops at the probe strike as it should.
I have this function in the screen load script and it is called from a button press.
Code: [Select]
function TestG31()
mc.mcCntlGcodeExecute(inst, "G31 G01 X-.20 F5")
mc.mcAxisHome(inst,0,0)
end
It doesn’t stop at the probe strike but finishes as a G01 X-.20 command. I eventually would like this code in the RefAllHome() function to stop on an encoder Index pulse.
Any help with this would be appreciated.
Title: Re: G31 not working in screen function
Post by: Bill_O on December 17, 2020, 09:20:23 AM
Do not put the G1 in the code.
Post by: Tony Bullard on December 17, 2020, 09:42:00 AM
Thank you! That worked. I've been fighting with this for a week. I really do appreciate your help.
Tony
Post by: Tony Bullard on December 17, 2020, 09:51:58 AM
I think I'll have to write a coroutine.yield() after the probe move for the rest of the code to execute properly. Stay tuned!
Post by: Bill_O on December 17, 2020, 09:53:15 AM
Glad I could help someone.
I have gotten a lot of help on here.
Post by: Bill_O on December 17, 2020, 02:45:58 PM
Use mc.mcCntlGcodeExecuteWait
Post by: Tony Bullard on December 18, 2020, 06:29:25 AM
The trouble with mc.mcCntlGcodeExecuteWait is that it pauses the PLC script while it is waiting so the position DROs in the GUI don’t update until it is done.
DasTheGas has a great tutorial on coroutines that explains this: https://www.youtube.com/watch?v=t2xQYvAXT8o
Post by: Bill_O on December 18, 2020, 07:56:07 AM
True, but I do not need to know the exact position Mach does.
When it is done is fine for me.
