Mach Discussion => Mach4 General Discussion => Topic started by: markus506 on December 01, 2020, 08:23:28 AM
Title: Cutter compensation issue
Post by: markus506 on December 01, 2020, 08:23:28 AM
Hi all,
I am having issues with cutter compensation. We are using an end mill to rough around a waterjet cut blank. The blank is a complex shape with multiple radii. When using cutter compensation, the smaller radius have a circle path drawn, cutting into the material. When turning off compensation, the part appears normal. Any ideas what could be going on?. Any help would be appreciated.
-Mark
Title: Re: Cutter compensation issue
Post by: Graham Waterworth on December 02, 2020, 11:37:41 AM
The cutter comp only works if the tool radius is smaller than the smallest radius on the part.
Post by: markus506 on December 02, 2020, 05:27:37 PM
Yes, the smallest part radius is larger than the tool radius.
Post by: daniba73 on December 03, 2020, 12:50:58 AM
Post the Gcode..
