Mach Discussion => Mach4 General Discussion => Topic started by: BigRay on November 29, 2020, 01:08:39 AM
I'm trying to use the vacuum button in the standard router profile in Mach 4. I went to "Edit Screen" and I couldn't seem to find an output drop down that can be used to assign an output on the controller, in this case Output 3.
I could see that it has a M100 and M101 attached to the button, so I tried to edit the output from 51 to 3 but this didn't work. I obviously didn't do it right and was wondering if someone might be able to tell me what I did wrong.
Ray
Any help or comment?
Did you change the Output# to Output3 in the button in the screen and the macro?
That should be the only thing you need to do. Change that number from 51 to 3 and you'll be good.
