Mach Discussion => Mach4 General Discussion => Topic started by: kevinallein on November 14, 2020, 04:36:01 AM
Hi, I am using MACH4 using the Ethernet Smooth Stepper. I have build a pendant with two rotary encoders and mapped them to the ESS Encoder Aux 0 and 1. I can see, in the Diagnostic Screen of the ESS, that Aux 0 and Aux 1 MPG are following the movement of the rotary encoders. I have assigned MPG0 and MPG1 of MACH4 to those and followed many of the instructions for LUA scripts adding the following lines:
mc.mcMpgSetAxis(inst, 0, 0) --Map the MPG 0 to control the X Axis
mc.mcMpgSetAxis(inst, 1, 2) --Map the MPG 1 to control the Z Axis
I also have a speed switch to select the speed of the movement and use the following lines to set the speed:
mc.mcMpgSetInc(inst, 0, PendantDistanceX1 )
mc.mcMpgSetInc(inst, 1, PendantDistanceX1 )
When I change the speed button, I can see the output message, that those commands got executed.
However I never see movement of my motors. I can move them with the jog buttons or the key on my computer keyboard, but not with the pendant. What am I missing ? Is there any way to observe MPG0 and MPG1 values simalar to the diagnostics of the ESS ?
Thanks in advance for any help
Problem solved. When assigning the MPGs in MACH4 the window was so small, that I could not see, that I had assigned ESS_Encoder_0 / 1 instead of ESS_Encoder_Aux_0 / 1.
