Mach Discussion => General Mach Discussion => Topic started by: JoonasM on October 27, 2020, 05:47:24 AM
Hello
I was wondering, if Mach3 has the ability to run through the job boundaries without manually having to move it. Right now, what I do is load the g-code and then manually see if the material is inside the job boundaries. But my question is, is there a way to make Mach3 do it itself? I hope you get what I mean here, I really do not know the proper words for this function. It should work the same as some chinese lasers have the "Frame" button on them.
Have a good one everybody.
