Mach Discussion => General Mach Discussion => Topic started by: BillC on October 02, 2020, 09:10:15 AM
Title: How to get rid of pauses between different segments of a program
Post by: BillC on October 02, 2020, 09:10:15 AM
A project I am working has 6 different sections.  There is one tool change and I do separate the sections for that.  I have saved the files that use the same tool together and want to run those as a single continuous program but when I do so there are pauses that I don't want.  I guess the question is, what commands do I remove to get it run non stop?  When I bring up the programs to edit them I can see where the programs change but I do not know what to info  :-\remove, if I even can.  What this means is I can't leave the machine to run to program completion.
Title: Re: How to get rid of pauses between different segments of a program
Post by: Tweakie.CNC on October 03, 2020, 12:21:51 AM
Zip and post your problem Gcode file then we should be able to resolve the issue.
Post by: notselrach1 on October 03, 2020, 01:18:33 PM
As per request I have zipped the programs I want to run seamlessly instead of pausing between each section...
Post by: Tweakie.CNC on October 04, 2020, 02:56:31 AM
Looks like your .zip file was edited out - could you perhaps try again.
Post by: notselrach1 on October 04, 2020, 10:24:25 PM
Here is the zip file...
Post by: Tweakie.CNC on October 05, 2020, 12:52:51 AM
You attached an .exe file which was deleted.
Please .zip your problem Gcode file and attach it as a .zip file.
