Third party software and hardware support forums. => HiCON Motion Controller => Topic started by: Wallerawang on September 28, 2020, 05:03:36 AM
Title: FIFO Overflow Error
Post by: Wallerawang on September 28, 2020, 05:03:36 AM
Hello,
I have been getting an error - FIFO Overflow Error - Vector level : 316 Buffer size 1622 and another time with Vector level :365 Buffer size 1754.
This has caused the board to disconnect and the job to stop. Is this a Mach4 issue or something to do with my HiCON board settings? - I guess it's the HiCON as the board is disconnecting when it happens.
Any Clues please?
Steve
Title: Re: FIFO Overflow Error
Post by: Vital System Support on September 29, 2020, 10:35:08 AM
Hello,
Most likely the FIFO buffer level in the plugin system tab is set too high. Try setting the max buffer level to 80 and the polling frequency to 120 and see if this alleviates your issue.
VitalSystem Support Team
Post by: Wallerawang on September 29, 2020, 03:44:08 PM
Thank You
I'll give this a try after work today.
Steve
Post by: Wallerawang on September 30, 2020, 04:19:34 AM
Hi - Thank you - that did the trick, I ran a 2 hour programme with no issues this afternoon. I think in the past I increased the buffer as I got another error message about running out of data or something like that, but I must have went too far - anyway all good now.
Steve
