Mach Discussion => Mach4 General Discussion => Mach4 Plugins => Topic started by: REECE on September 25, 2020, 01:50:27 PM
Title: Pokeys57cnc Homing is Triggering the Limit Switch
Post by: REECE on September 25, 2020, 01:50:27 PM
Hi!
Having an issue with homing my machine and looking for some help!
I'm currently building my first machine using Mach4 and Pokeys57cnc. I'm trying to use the same switch for the limit and for homing on each axis. When I home the machine, it hits the switch and then triggers the limit. The machine doesn't even back off the switch at all while homing. It homes until it hits the switch and then triggers the limit switch immediately and stops the machine. Happening on all the axes.
Any suggestions on how to fix this?
Reece
Title: Re: Pokeys57cnc Homing is Triggering the Limit Switch
Post by: reuelt on September 25, 2020, 11:57:43 PM
Hi!
Reece
Home and limit switch behaviour for each axis (in your case) has to be configured in the
"Axis configuration panel" of Pokeys57CNC plugin too.
Post by: REECE on September 26, 2020, 02:35:54 PM
Solved. Thanks.
