Mach Discussion => General Mach Discussion => Topic started by: derek on October 02, 2007, 05:56:17 AM
Title: Question on OD Arc 3 In turn wizards
Post by: derek on October 02, 2007, 05:56:17 AM
How does the wizard work without knowing the profile or dimensions of the cutting tool?
Derek
Title: Re: Question on OD Arc 3 In turn wizards
Post by: Hood on October 04, 2007, 02:01:06 PM
Never tried the wizard yet as my Lathe is just in the final stages of the retrofit but I presume you are meant to use a tool with similar shape as is in the wizard.
Post by: DAlgie on October 07, 2007, 02:00:08 PM
None of the wizard profiles have reentrant cycles in them so it really doesen't matter at all. The main thing is the tool tip radius, which it will use.
             DaveA.
