Mach Discussion => General Mach Discussion => Topic started by: mtabernig on August 24, 2020, 11:53:48 PM
I send the machine home and, after it gets there, I can zero the dros with no problem. When I press and activate the "Machine Coordinates" button the dros are set to the the middle of the table. I try to zero with the buttons, nothing happens. Try by pressing the home button, nothing happens.
Yes I have home switches and everything else works. Without homing the machine coordinates I can not activate the soft stops, already entered the values and activated the Y and X not the Z.
Well as a new user I need a bit of help. Thank you.
Perhaps take a look at Roger's pdf which explains the coordinate system. It can be downloaded from here; https://www.machsupport.com/forum/index.php?topic=33595.0
