Mach Discussion => General Mach Discussion => Topic started by: mtabernig on August 08, 2020, 05:36:18 PM
Title: How to reset Mach3 to the original complete default
Post by: mtabernig on August 08, 2020, 05:36:18 PM
I purchased a new mach 3 and after tuning motors and edge stops  I can get nothing to work and everything is getting worst. I like to know if there is a way to reset the entire software to factory default and restart all the calibration again.
I will really be appreciative about any solution.
Post by: mtabernig on August 09, 2020, 02:45:49 PM
I wanted to include some information. Everything wha sort of working then I started to get the end tops, the hard stops, to work now I can't get nothing to move.     I would like to reset the entire software to the original default....desperate here!!
I work with the demo version of Mach3 for 4 years and nothing like this had ever happened. I am a hobbyist and I decided to take a plunge and purchase the software if Only can start over.
Title: Re: How to reset Mach3 to the original complete default
Post by: ZASto on August 09, 2020, 04:17:40 PM
If you REALLY want to start from scratch, just save your license file to a safe place, delete entirely C:\Mach3 folder, download fresh copy of software from NFS site, install it, copy back your license file, and you are "fresh as new".
And, also, if you use some specific macros and/or screen sets, copy those to a safe place before deleting Mach3 folder.
Post by: mtabernig on August 09, 2020, 06:31:54 PM
Thank you for the response. However I am using a new computer with a serial port in lew of a parallel port and I had a problem installing the EU 100  or a similar name and someone help me with that. If I remove everything i will have the same problem. I just like to reset all defaults and be done, if that is possible.
Post by: ZASto on August 09, 2020, 06:59:41 PM
Serial port?
What for are you using serial port?
MODBUS or something else?
Post by: mtabernig on August 09, 2020, 07:54:31 PM
The serial port  on the newer computers disappear, however, I connected the serial port to a UB100" or some near that name" to convert the serial port to a parallel port and be able to assign the pin numbers to the proper port and pins. I did not that existed and I was trying  to use an old computer with windows XP. Now I am using a new Dell with windows 10 and the adaptermention above.
Post by: Tweakie.CNC on August 10, 2020, 12:10:48 AM
Are you using the UC100 connected to a USB port on your PC and does it look exactly like this or is it slightly different ?
(http://cncdrive.com/img/UC100.jpg)
Post by: mtabernig on August 10, 2020, 12:26:50 AM
yes, it is exactly like that.
Post by: Tweakie.CNC on August 10, 2020, 12:34:41 AM
 All of the setting-up information for the UC100 is here; http://cncdrive.com/UC100.html
Use their installer and follow the on-screen instructions.
Post by: mtabernig on August 10, 2020, 12:42:49 AM
Thank you
Post by: mtabernig on August 10, 2020, 09:03:17 PM
Thank you all. I reinstalled mach3 and i had problems with the motors again for some reason, I replace the motors with ones that have more power and work find even with the current cut way down. I think that I burnt the original motors when I live the idling for long times with the machine on but not having anything moving.
Is any command to cut power to the motors after the end of the code?
Post by: mtabernig on August 10, 2020, 09:53:58 PM
Sorry; however, I forgot a detail that may be significant.
Before, when I was running the demo version for about 3 years I never had the motors locked up, with current flowing, after the program stop or before start..... is there some difference in this regard on the register version and the demo one?
Post by: Tweakie.CNC on August 11, 2020, 12:16:59 AM
Not within Mach3 but most motor drivers (ie.. TBA6560 etc.) incorporate a reduced stand-by current setting.
Best to adjust your driver current setting so that your motors outside case temp never exceeds 60 deg.C (even when stationary for long periods).
There is no difference between the licensed and demo versions of Mach3 in this respect.
Post by: mtabernig on August 11, 2020, 10:25:27 AM
I will check the option of reduced current on stand by. Right now what I did was to install  bigger motors than needed ar a reduced current; they are working just fine but I am afraid and I turn off the power supply to the drivers in standby.
Thank you all for everything, and being willing to share with us ,"newbies", your knowledge and experiences.
Mtabernig
