Mach Discussion => Mach4 General Discussion => Topic started by: devinw on August 01, 2020, 06:20:21 PM
I am trying to open an g code in Mach4 hobby and it always just sits at "tool path progress" at 0% and never loads. If you cancel and hit Regen tool path , same thing.
I've tried the sample codes that come with Mach4 and always the same result. Somebody please help me!!
Well, I don't know what I did, but it seems to work for now. I even ran some code. Fingers crossed.
I know the thread is old, but I started having this problem with every new gcode file I created after about March 10. All my pre-March files load into Mach-4 Hobby just fine. I use Fusion360 to make the g-code.
Does anyone know if something changed in Fusion360? If so, do I fix the problem by changing a setting in Fusion or in Mach4. My Mach4 version is about 2-3 years old.
Thanks for any help.
