Mach Discussion => Mach4 General Discussion => Topic started by: KatzYaakov on July 24, 2020, 01:19:57 AM
i try load big nc file
after the file finish to load ,i got this error
never see
is some one matt such error?
i try send here the file but its 25Mb cant send here
when i cut to half its let mach load it
but freinds its very confused because all chines cheap system can load such program only our cant??
What version are you using
4.2.0.4300
25MB! How big is this thing! We can make a mode where it works but you will not have the toolpath and so on. You need some good hardware to make that happen.
its not such big(as you can see at atach i can use ony half part ,if i not cut the file its cant load)
what do i need to do to run this complete file?
