Mach Discussion => General Mach Discussion => Topic started by: Closkar on July 21, 2020, 05:42:01 AM
Title: Mach3 running too slowly
Post by: Closkar on July 21, 2020, 05:42:01 AM
Hello,
perhaps someone out there can understand my problem - described in poor English. My milling machine: Genmitsu CNC Router 3018-MX3 (Sain Smart).
G-code that is working in DrufelCNC hardly moves the motors of x, y and z. Manually activated the spindle can be moved in every direction with normal speed.
Which parameters should be changed? Closkar
Title: Re: Mach3 running too slowly
Post by: Closkar on July 21, 2020, 01:00:40 PM
My problem is solved:
My mill was accompanied by a small CD containing the file MACH3MILL.XML
This file has to be copied to the installation directory. When Mach3 is running the data in this file are modified and the file is saved. After I had copied the original file once more into the Mach3 directory everything worked as expected. I hope to solve possible future problems in the same way. Closkar
