Third party software and hardware support forums. => Newfangled Mill Wizard => Topic started by: joeaverage on July 03, 2020, 08:51:51 PM
Title: Can I add to the Tool Library??
Post by: joeaverage on July 03, 2020, 08:51:51 PM
I use MillWizard alsmost daily, its so handy for doing small jobs.
I use 0.5mm, 0.8mm and 1.5mm endmils alot. The 0.8mm and 1.5mm are four flute and the 0.5mm
are two flute.
When I go to do a new job you have to select the tool but none of these endmills occurr in the tool library.
I've not found a way to include my go-to tools in the library. Is there some technique or manipulation that I'm
missing?
Title: Re: Can I add to the Tool Library??
Post by: Graham Waterworth on July 05, 2020, 08:18:30 AM
The tool table is in the config menu
Post by: joeaverage on July 05, 2020, 02:06:12 PM
kool, thankyou.
