Mach Discussion => General Mach Discussion => Topic started by: StuartW on June 19, 2020, 06:29:31 AM
Hi there I have attached 1 Macros, newbie here I am trying to work out why the pdb wont close and gives me the error pdb failed (tool not secure). when it actually has opened and closed correctly.All help appreciated. Stuart
This is thr M6Start file if needed, I have been trying for many hours to work this out and am lost. regards Stuart
Are you running Mach3 or Mach4 because you have files from both here M6Start.mcc is compiled Mach4 Lua and M131.m1s is Visual Basic from Mach3
I am running Mach3 only. regards Stuart
So the M6Start.mcc is not a Mach3 file, so we need your M6Start.m1s file from your working profile.
Do you have a tool change page on your screen, if so post a picture of that too.
I have attached I had to change the name as it would not let me upload it as start.M1s file regards Stuart
Is this the .set file you mean?
Can anyone help me with this problem? All help appreciated regards Stuart
There is far more to this than just a screen set, there are images and macros too.
Hi Graham I can send you the whole mach3 folder privately which would make it far easier to investigate if you like? regards Stuart
