Mach Discussion => General Mach Discussion => Topic started by: jammer0357 on June 17, 2020, 07:08:23 PM
I recently purchased a Novusun usb breakout board. The install went well and x,y and z axis's worked very well. After a little motor tuning I was able to get all 3 within .001 inch which i think is outstanding for a cnc router. Then the trouble started. I hooked my drive to the spindle output and got nothing. Now maybe I'm being silly but shouldn't I be able to read DC voltage out of a 0 to 10 volt analog output. I have everything set up according to the manual. Did I miss something? . I contacted the seller and sent pictures of everything,wiring and Mach3 settings. they said all looked good but can't give me a reason for the fail. I would appreciate any help.
unfortunately Novosun is on the 'blacklist' as a company that peddles pirate copies of Mach3 and you will get no
support here.
That may change if you have a genuine Mach3 license, I would PM the forum moderator to discuss the license situation.
Hi Jammer0357,
As Craig has mentioned, the forum does not provide support for Novusun products.
This thread refers; https://www.machsupport.com/forum/index.php?topic=24331.0
