Mach Discussion => General Mach Discussion => Topic started by: Alchematic on June 09, 2020, 02:12:22 PM
Title: Can Mach 3 output a logic high and low corresponding to Z axis direction?
Post by: Alchematic on June 09, 2020, 02:12:22 PM
I am setting up a new system for an old engraving table. Using Mach3 thru ethernet smooth stepper to leadshine mx3660 and to steppers for x and y axis.
The z axis is a air actuated spindle by New Hermes for fine engraving.
I need to turn on a relay driven air valve solenoid when the z axis starts a plunge or downward motion and off when the z axis retracts. The action of the plunger is fast.
There is of course no z axis stepper motor. I just need a logic signal on an mx3660 output that corresponds to the direction a z axis stepper would move if there was one.
Is there any way to set up an initial line of code that would output this logic.. Logic high when z axis is plunging (down) and Logic low when z axis retracts (up)
Logic polarity is of no concern. I can set that up with hardware.
I am most likely gong to use Vcarve to generate gcode but they do not have a solution for this so far.
Mark
Title: Re: Can Mach 3 output a logic high and low corresponding to Z axis direction?
Post by: Tweakie.CNC on June 10, 2020, 12:41:09 AM
The Z Axis Direction signal will toggle between the High and Low state dependant on axis direction movement. The signal is persistent and retains it's state until changed.
Post by: Alchematic on June 10, 2020, 11:40:47 AM
Hi Tweakie.
Thanks for the reply.
Yes I understand that it is a steady state High and Low dependent on direction.
Researching this more yesterday, I came up with this..
Ethernet Smooth Stepper puts out Z axis Move Pulses on pin 6 and Direction on Pin 7
I want to access that Pin 7 signal.
I thought I might do it in hardware with a DB25 male to female with breakout and jump pin 7 to the Pin 9 which would give me that direction signal on the MX3660 CN7 digital output 4
I might have to break the normal/ circuit trace from the pin 9 of the input DB25 to avoid conflict.
I am checking with Warp9 to make sure that Z Axis Direction pin 7 can feed 2 input without loading. It should.
Then I got to looking at Mach 4 and the ESS setup. There is a new feature where you can assign Output signals to multiple pins.
This is done on the ESS Configuration App and Output Signals tab.
So I am hopefull that I can just send the Z Axis direction to Pin 7 as is normal and to Pin 9 to feed the MX3660 digital out 4
Post by: Tweakie.CNC on June 11, 2020, 12:43:59 AM
Looks good.
Post by: Tweakie.CNC on June 12, 2020, 02:02:38 AM
For others that follow, there is more information on the Warp9 forum. https://www.warp9td.com/index.php/kunena/7-general-discussion/8448-ess-mapping-outputs-with-mac4#24748
