G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Merlin1965 on May 31, 2020, 12:12:10 AM
Hi Guys
I seem to get this little extra loop cut that is not required
Pic attached of Screen shot
Also attached my G code file
Any Help appreciated
John Perkins
some how I did not attach the screen shot
JP
I have the same issue and are yet to find the answer
I posted a very similar question before finding this thread
suppose i should use search first .....ooops
John P
Hi guys,
This is really weird and something I have never come across before.
Which version of Mach3 are you using and which motion controller ?
Hi Tweakie
Thanks for closing other thread
I Have Current Version of Mach 3 and are using a UCCNC- AXBB-E controller
John P
Hi John,
In Mach3; Help / About will show the Mach3 version number. Which version are you using ?
Sorry but I was thinking of other things when I mentioned Motion Controller I should have said what CAD/CAM software are you using to generate the Gcode ?
Mach 3
I have Version R3.043.062
I don't use cad/cam ...I write my own code ...then i can Understand the errors ..I often will run program with steppers off to see any errors or do a test run in MDF
I have added pic of machine
John P
Hi John,
Very nice looking machine.
You are using the latest / best version of Mach3.
There is something not quite right dimensionally with your Gcode file but I am not clever enough to spot where the problem lies. I suspect that Mach3 thinks there is not enough room to apply the cutter radius compensation (lead-in) so it takes an alternative path.
Incidentally UCCNC also reports cutter radius compensation warnings when your Gcode file is loaded which may confirm a Gcode dimensional error is present.
Tweakie is correct. IF mach3 sees that the leadin is too short for teh tool it will create a path to make it work. Normally the path will be incorrect when it does so. One of Mach3 quirks.
I would not trust UCCNC error codes either as teh G41 in that controller has quirks of its own.
Just a thought , (;-) TP
