Mach Discussion => Mach4 General Discussion => Topic started by: jcassar on April 15, 2020, 08:14:35 AM
Hello,
Trying to understand how the video panel work. The documentation is not updated, so trying to discover this new widget. I successfully connected to a local video cam, and video is displayed with no problem.
This video object got an image property, with several images listed. I cannot find any reference of them on the full drive, so wondering if this is generated or may be embedded in one of Mach4 files. The idea will be to add my own one.
Well if anyone could light on or share his/her experience on this subject, will be great.
Stay safe.....
JP
The image property is an image that you import into the Mach screen set. Just like you would do for a bitmap button, etc... When you are editing the screen, look at the Screen -> Manage Images menu item.
Attached is an example of how to use the image property. It should be a transparent background PNG file.
Steve
:D
Thank you! At least I know now where the image library is!!!
Take care.
