Mach Discussion => Mach4 General Discussion => Mach4 Toolbox => Topic started by: AXYZ_WI on March 29, 2020, 04:21:34 PM
Here's my Mach4 tool change. I took many concepts from others on this forum so thank you. It has user parameters that let you tell it if you use a tool setter permanently located or a movable touch plate. You can also tell it it you control the spindle or if Mach4 does with M3/M5 commands.
Here's a video of it in action and a quick explanation of the code.
https://youtu.be/kVqPkZG9ha4
-----------------------------------------------TLAR SMART TOOL CHANGE - Rev.1 03/2020------------------------------------------------------------
---------------------------https://www.youtube.com/channel/UCVMC1IaXdFonuWAGrmyUNmg?view_as=subscriber-------------------------------------------
------------------This tool change script assumes your spindle uses a collet and collet nut to retain the tool.----------------------------------
--------------------------------Before continuing, insure your input signals and mapping are correct---------------------------------------------
------Manual tool change uses a G31 command, AutoTool change with the tool setter uses a G31.1 command. The difference is the imput signal!!-----
function M6()
local inst = mc.mcGetInstance();
-------------------------------------------User inputs--------------------------------------------------------------------------------------
local ManualChange = false --True for manual change false for auto change You ****YOU MUST HAVE RELIABLE HOMING X Y and Z FOR AUTO TOOL CHANGE!!****
local SpindleControl = true -- Can Mach4 controll your spindle? True for M3/M5commands, false for manual spindle control.
--------------------------------Auto Tool Change specific----------------------------------------------------------------------------------
local xprobe = 93.6 --Machine Coordinate of the tool setter on X axis
local yprobe = 2.375 --Machine Coordinate of the tool setter on Y axis
local XToolchangePosition = 93.6332 --Machine Coordinate of where you want to change your tool on X axis
local YToolchangePosition = 5 --Machine Coordinate of where you want to change your tool on Y axis
------------------------------------Tool information----------------------------------------------------------------------------------------
local DefaultToolLength = 2 -- Must be at least as long or longer then your longest tool This is what's used if your tool table is not filled in.
local ColletAtProbeZCoordinate = -6.07 -- This is the distance from home Z must travel for the collet without a tool to hit the tool setter
local ExtraProbeDistance = .75 -- This is your margin of error the smaller this number the larger the pucker factor.
local ProbePrepSpeed = 20 -- This is how fast Z travels before it slows down to probe. The larger this number, the larger the pucker factor.
local ProbeOperationDistance = -2.25 -- This is how far Z will move while looking for a probe hit.
local ProbeSpeed = 5 -- This is how fast Z will probe at. Keep this number small for acuracy.
local SpindleDwell = 10000 -- this is the amount of time to wait in microseconds for the spindle to stop or start spinning. Example is 10 seconds
--------------------------------------End of user input-----------------------------------------------------------------------------------------
local selectedtool = mc.mcToolGetSelected(inst)
local currenttool = mc.mcToolGetCurrent(inst)
local xstart = mc.mcAxisGetPos(inst,0)
local ystart = mc.mcAxisGetPos(inst,1)
if selectedtool == currenttool then
mc.mcCntlSetLastError(inst, "ToolChange Activated But Not Required, That Looks About Right")
return
end
mc.mcCntlSetLastError(inst, "TLAR Smart Tool Change Activated!")
if SpindleControl == true then
mc.mcCntlGcodeExecute(inst, "M5 G4 P"..SpindleDwell)
else
wx.wxMessageBox("Turn off your spindle\nClick ok to continue.")
end
if ManualChange == true then
wx.wxMessageBox("Click OK, Then Jog to A Safe Tool Change Position\nJog Z axiz close to the touch plate,\nThen Click Cycle Start.","Click OK to continue")
mc.mcCntlToolChangeManual(inst,true)
else
mc.mcCntlGcodeExecuteWait(inst,"G90 G53 G0 Z0.0 \n G90 G53 G0 Y"..yprobe.."\n G90 G53 G0 X"..xprobe)
end
RunProbe(currenttool, DefaultToolLength, ColletAtProbeZCoordinate, ExtraProbeDistance, ProbePrepSpeed, ProbeOperationDistance, ProbeSpeed, ManualChange)
local toolz = mc.mcAxisGetPos(inst,2)
mc.mcCntlGcodeExecuteWait(inst,"G90 G53 G0 Z0.0")
if ManualChange == false then
mc.mcCntlGcodeExecuteWait(inst, "G90 G53 G0 X"..XToolchangePosition.."Y"..YToolchangePosition)
end
local changetoo = mc.mcToolGetDesc(inst,selectedtool)
wx.wxMessageBox("Please change too tool number "..selectedtool.."\n "..changetoo.." and press ok to continue")
wx.wxMessageBox("Click OK, Then jog Z axis close to the touch plate and press Cycle Start.\nClick OK to Continue ")
else
mc.mcCntlGcodeExecuteWait(inst,"G90 G53 G0 X"..xprobe.."Y"..yprobe)
end
RunProbe(selectedtool, DefaultToolLength, ColletAtProbeZCoordinate, ExtraProbeDistance, ProbePrepSpeed, ProbeOperationDistance, ProbeSpeed, ManualChange)
mc.mcAxisSetPos(inst, 2 ,toolz)
wx.wxMessageBox("Remove touch plate and aligator clip from router\nGantry will move and motor will spin and continue GCode\nPress ok to Continue")
end
mc.mcToolSetCurrent(inst, selectedtool)
mc.mcCntlGcodeExecute(inst, "M3 G4 P"..SpindleDwell)
else
wx.wxMessageBox("Turn on spindle\nClick ok to continue")
end
mc.mcCntlGcodeExecuteWait(inst,"G90 G0 X"..xstart.." Y"..ystart)
mc.mcCntlSetLastError(inst, "TLAR Smart ToolChange Finished")
end
function RunProbe(tool, DefaultToolLength, ColletAtProbeZCoordinate, ExtraProbeDistance, ProbePrepSpeed, ProbeOperationDistance, ProbeSpeed, ManualChange)
local toollen = mc.mcToolGetData(inst, mc.MTOOL_MILL_HEIGHT, tool)
if toollen == 0 then toollen = DefaultToolLength -- User Preference
mc.mcCntlSetLastError(inst, "Changing to default tool length Fill in your tool table!")
end
local probestart = ColletAtProbeZCoordinate + ExtraProbeDistance + toollen
mc.mcCntlGcodeExecuteWait(inst,"G91 G31 Z"..ProbeOperationDistance.." F"..ProbeSpeed)
else
mc.mcCntlGcodeExecuteWait(inst,"G90 G53 G0 Z"..probestart.."F"..ProbePrepSpeed.."\n G91 G31.1 Z"..ProbeOperationDistance.." F"..ProbeSpeed)
end
end
if (mc.mcInEditor() == 1)
then M6()
end
--Rev 1 Change log.
--Added Spindle Control true/false
--Added manualChange true/false
--Added SpindleDwell parameter
When I put this code in my m6.mcs and type m6 in MDI, half of the screen buttons gray momentarily, and then nothing happens. I assume there is a Lua error.
The default m6.mcs script will run in MDI.
Why does Mach4 not tell us what the error is?
Does anybody know a good fix?
This code will run in script editor when I click the double arrows.
Are you telling it what tool you want? M6 T3 for example.
Yes. Thanks for all your good work.
I'm using Mach4 on Win10, and the whole thing is remarkably buggie. I reinstalled the controller board and Mach4, and that seemed to help a little.
I simplified your code to the extent possible and I stripped the code down to the bare minimum that I needed for my tool changes on a homemade mill, and then a lot of trial and error to get it to run. Here's the code I ended up with:
function m6()
local selectedTool = mc.mcToolGetSelected(inst)
selectedTool = math.tointeger(selectedTool)
local currentTool = mc.mcToolGetCurrent(inst)
currentTool = math.tointeger(currentTool)
local ProbeOperationDistance = -15 -- This is how far Z will move while looking for a probe hit.
local ProbeSpeed = 15 -- This is how fast Z will probe at. Keep this number small for acuracy.
if selectedTool == currentTool then
mc.mcCntlSetLastError(inst, "Current tool == Selected tool so there is nothing to do")
else
mc.mcCntlSetLastError(inst, "Tool Change")
mc.mcCntlGcodeExecuteWait(inst,"G90 G53 G0 Z0.0 X0.0 Y0.0")
mc.mcCntlSetLastError(inst, "Position the tool less than 1/2 inch over the touch plate and click Start")
local toolz = mc.mcAxisGetPos(inst, 2)
mc.mcCntlSetLastError(inst, "Change the tool, reposition it over touch plate and click Start")
mc.mcAxisSetPos(inst, 2, toolz)
mc.mcCntlSetLastError(inst, "Turn the spindle on, click cycle start, and we are cutting.")
end
end
if (mc.mcInEditor() == 1) then
m6()
end
Is there a way to update this for those of us that dot have touch off plates ad do manual tool changes? Im still old school using the paper trick.
The 2 occurances of M6 need to be changed to m6. Mach4 strips m codes to lowercase and then looks for scrips and functions using the same case.
