Mach Discussion => Mach4 General Discussion => Topic started by: Tesla619 on March 28, 2020, 11:31:28 AM
Title: Mach 4 skipping steps
Post by: Tesla619 on March 28, 2020, 11:31:28 AM
Hello all, i am new to Mach. I purchased an AVID CNC 4x8' cnc machine. The only thing needed was the assembly. The pack=age had a pre-calibrated Mach 4 for that machine.
Long story, i have checked all cables and tried for hours. I home, use a touch probe for all axis, then start the machine. I am drilling 1/4" holes on a 17" by 97" board. I noticed a few holes in order was miss drilled. So i stop the machine, go to X Y work area, notice where it went was .50 off on X and .20 on Y. This explains the miss-aligned holes. So i home the machine then tell it go to X Y work area ad it is correct. So i send it back to drill.... the same issue and this time it goes to the pre-drilled areas snf makes them oval....this keeps happening.
http://www.cncrouterparts.com/pro4896-4-x-8-cnc-router-kit-p-253.html
Title: Re: Mach 4 skipping steps
Post by: jeep534 on March 28, 2020, 05:50:11 PM
the first thing I woild do would be get a seperate power feed to the router  as to seperate it from the control cables to eleminate the chance of noise causing a problem then work from there
may or may not clear up the problem but it will check a troubleshooting box
happy hunting
archie
