Mach Discussion => Mach4 General Discussion => Topic started by: Mini on March 23, 2020, 07:21:53 PM
Having an unusual problem with Mach 4. I am running Windows 10 and if I shut down Mach 4, the next time that I start it up again, I get an error message telling me that there is another version of Mach 4 running. The only way that I can start Mach 4 is if I use Windows Task Manager to end the task. As long as I use Task Manager to shut down Mach 4, it will start right up next time that I use it and run great. Anyone have any idea what is going on and how to fix it?
Richard
Some plugin is keeping Mach from shutting down. Copy your profile and launch it. Then disable each plugin, one by one, until the problem goes away.
Steve
Steve
Thanks, that makes sense, I'll try that.
Richard
