Mach Discussion => General Mach Discussion => Topic started by: 6040ZCNCNovice on March 22, 2020, 02:39:19 PM
I have 2 e-stops and I am trying to wire them in series to a g-540 and have them read on the Mach 3 screen. I can get one or the other to work, light up / lock out on mach-3 screen, but not the second. The second works, but does not lock out the mach 3 screen. I am not sure if my issue is in software or wiring.
I am also confused why some of the things i see for e-stop settings show I should be using port and pin 1 - 10 for my e-stop settings when port and pin 1-15 is the only one that seems to work. port and pin 1-15 is what i am using
Would anyone have a pictorial schematic of how to correctly wire the e-stops and know what setting should be used?
Thanks in advance
Novice
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
Mach 3 - Ver 3.043.066
G540 Rev 5
Post Processor: Mach3 2/3 arcs (Inch)
Motors-57BYGH433-06BS
ok...... one wire comes from the breakout board to the first estop switch (normally closed) from the other side of that switch go to the second switch (normally closed ) from the other side of that switch back to the breakout board.... bouth switches have to be out (in the closed position) or the machine to run....
Happy Hiunting
archie
Thank you.
did this help ie did that work
you are very welcome
happy hunting
archie
Let me ask the question another way...
Imagine I have the following two controllers both working different sections of my CNC. The black one controls the spindle and the other controls the motors through a G-540. All work fine except the e-stops.
How would I wire the e-stops so they both work on both systems WITHOUT blowing up either controller??
Currently, the black box e-stop kills the spindle, but does not show up on the mach3 screen or kill the second box.
The second box e-stop kills the 3 motors, does not kill the black box, but DOES show up in Mach 3
Novice
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
G540 Rev 5
Top view of actual boxes
Novice
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
G540 Rev 5
I am going to assume this is a router and the only way I see to do this is to have mach3 control the spindle and have only one estop controlling mach 3 now... my arms are not long enough to fix this issue....
is this something you bought
what kind of breakout board motion controller do you have and what is the black box manufacturer and model.
archie
can you run dual contacts on each estop switch?
you did not answer my question
I assume your goal is for each E-Stop switch to kill power to all motors and signal the Mach 3 controller.
Each box would need to be modified to accept an external E-Stop signal, output an E-Stop signal to the other box and to signal Mach 3. This is not a trivial task. Details of each box will have to be known to plan the modification. It would be difficult, if not impossible, to obtain enough extra contacts to add to the existing E-Stop switches. Adding a small relay to each box can provide extra contacts.
Power for the relays would need to be available when the boxes are off. This means a supply not switched off in E-Stop mode.
Contacts from the relays would be substituted for the E-Stop switch contacts in each box.
The E-Stop switches contacts could then be used control the relays.
Contacts from each relay would be wired in series to signal the Mach 3 controller.
A simpler way to protect your machine would be to add an additional E-Stop circuit that kills power to the two boxes and signals Mach 3. More than one switch could used. The new E-Stop switches would need two contacts, one for power, one for Mach 3. The switches on the boxes would not be used in an emergency.
"I assume your goal is for each E-Stop switch to kill power to all motors and signal the Mach 3 controller." Yes
"can you run dual contacts on each estop switch?" I do not know the answer to this
"my arms are not long enough to fix this issue...." That's just too funny!! :)
"is this something you bought" Originally yes. The board in the black box failed and I obtained a G540 to control the motors. Gutted the black box and wired the G540 through the silver box. (Necessity is the mother of invention. Dumb luck covers the rest)
"what kind of breakout board motion controller do you have and what is the black box" - none - black box powers the spindle which is manually speed controlled via the dial on the box. See attached photo
"Manufacturer and model" Chinese SXCNC
think the easiest way would be to Change the e-stop button of the silver box to one witch has two NC contacts. eleminate the e-stop button
of the black box and put These two wires via a cable to the second contact of the e-stop button of the silver box.
Do you mean doing something like this?? (I am not sure so i am asking)
It appears you are showing a separate switch from the ones mounted on the boxes and are planning to replace both with this new one. That should work.
This leaves the problem of wiring the two E-Stops to the Mach 3. If each box has a contact for as the E-Stop output they can be wired in series as discussed earlier.
If not show us what you have.
"show us what you have"
1st one (black box) is a lay37(pbc) estop switch
Two switching circuits: 1 Normally Open + 1 Normally Closed (DPST: Double-Pole-Single-Throw)
Contact rating: 600V / 10A
Number of terminals: 4
seen here: https://www.aliexpress.com/item/4000135749528.html?src=google&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=1582410664&albag=59754279756&trgt=539263010115&crea=en4000135749528&netw=u&device=c&albpg=539263010115&albpd=en4000135749528&gclid=EAIaIQobChMIgdvJodu26AIVCo7ICh1k0AOTEAQYASABEgIHX_D_BwE&gclsrc=aw.ds
2nd one (silver box) is a Shisnao SAY7 - PBC Y090 LAY 37
LAY37-10ZS NO:normal open;LAY37-01ZS NC:normal close
seen here: https://www.aliexpress.com/item/32819686974.html?src=google&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=9594035441&albag=102695258807&trgt=296904913880&crea=en32819686974&netw=u&device=c&albpg=296904913880&albpd=en32819686974&gclid=EAIaIQobChMIpInindy26AIVlJOzCh0bQwVREAQYBCABEgLEq_D_BwE&gclsrc=aw.ds
Thanks everyone. I was way over thinking this. I removed the black one and rewired through the silver one.
Next... adding X, Y and Z limit switches.
Novice.
