Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: dmoore on March 21, 2020, 06:42:22 PM
Title: ShuttlePro V2 Different Hardware, Same Name with Sticking Outer Ring
Post by: dmoore on March 21, 2020, 06:42:22 PM
I thought I'd post this in case someone else runs into this issue.  The problem is that Mach3 when combined with the newest ShuttlePRO hardware, Mach3 will "stick" when the outside ring is turned and the axis will continue to move even after the ring returns to the center.  I'm awaiting a possible solution from Contour and I'll post it here.
Here is a photo of the "good" and "bad" boards.  Externally they look identical.
Title: Re: ShuttlePro V2 Different Hardware, Same Name with Sticking Outer Ring
Post by: dmoore on March 21, 2020, 06:49:50 PM
Here are the working and non-working chip photos.
