Mach Discussion => Mach4 General Discussion => Topic started by: habituralcnc on March 20, 2020, 10:50:32 PM
hello,
Anyone know how/code to select tabs with an external input signal?
trying to setup new screen with external physical buttons to select different tabs
any help appreciated
Regards
Amyl
Sorry not sure if posting in right place ???
Using mach4 is it possible to implement this in the signal script?
eg
[mc.ISIG_INPUT3] = function (state)
IF (state == 1) then
change tab to Machine Diagnostics tab/window :)
end
end
no idea if selecting tabs is implemented in the core or if even possible any ideas?
maybe to be more specific
is it possible to change variable "Current Tab" in Properties in Main Tabs in the Screen Tree Manager
with a series of mc.ISIG_INPUT functions?
is there a handle for Current Tab?
just trying to learn here
cheers
I don't know if its possible, and certainly if it is I don't know how...at the moment.
I would guess that it is possible and probably not too difficult....once you have determined how.
All I can do at the moment is show what I have found and hope that I or others can furnish other ideas until a
solution is reached.
My investigations to date are in the pics attached. All of these screenshots were take while in screen edit mode and
also I undocked the ScreenTreeManager so that the screenshot contained all the relevant images.
The first screen shot is the MainTabs entry of the ScreenTree and noice the Properties, particularly the
DefaultTab and the CurrentTab, both 0.
The second screen shot is when the ProgramExtentsTab is displayed and note now that the MainTabs properties have
changed such that the DefaultTab is still 0 but the CurrentTab=1.
The third screen shot is when the MachineDiagnostiicsTab is displayed and note how the MainTabs properties
have changed again such that the DefaultTab is still 0 but the CurrentTab=2.
The last screenshot follows the same pattern, namely that the tab displayed is ProbingTab and the CurrentTab property
is 3.
I conclude that:
CurrentTab=0 means ProgramRunTab
CurrentTab=1 means ProgramExtentsTab
CurrentTab=2 means ProbingTab
and by extension:
CurrentTab=4 means OffsetsTab
CurrentTab=5 means SurfaceTab
So it looks to me that there is a variable OR a property 'CurrentTab' which if we could manipulate it programmatically
would allow you to achieve what you want.
So the research continues into indentifying the variable and/or property of 'CurrentTab'. If anyone knows anything about
it please chime in.
Hi
Thanks for taking the time to reply much appreciated !!
This is also what i have figured out and if you change Current Tab variable (in Properties) it will select
different tabs .
thanks for the sense of direction that might be looking for a property
Im new to lua and trying to teach myself
Im using mach4 hobby , anyone know if this is an industrial mach4
feature? maybe not implemented in hobby ?
Best Regards
Amyl
Maybe something along the lines of
scr.SetProperty('MainTabs', 'Current Tab', '0')
stolen from:
https://www.machsupport.com/forum/index.php?topic=30831.0
DazTheGas post
if this is correct how or were to implement this anyone have any idea?
scr.SetProperty('MainTabs', 'Current Tab', '3')
end
end
wow this acturaly works cool
put it in screen load script simple ! not sure if its the most efficient
way but it works hehe
end
end
excellent work!
As if often the case once you have devised a strategy for achieving a particular goal the actual coding
of it is trivial.
As a matter of programming style; directly using the 'scr.*********' table is not recommended. In most cases there is
an API or Mach variable that is 'exposed' for the purpose of customization...not withstanding the the scr.********* functions
can do the job. That is Smurph's recommendation anyway.
I myself am rather mystified by the syntax of the scr.********* table. I did find and post a list of the table entries:
https://www.machsupport.com/forum/index.php?topic=40051.msg271116#msg271116 (https://www.machsupport.com/forum/index.php?topic=40051.msg271116#msg271116)
Smurph has rather pointedly reminded us all to avoid many of the functions contained therein.
In this instance however you are using one of the basic and popular scr.********* functions and should be OK. The fact that
you have used the SigLib{} table speaks very well of the effort to learn Mach/Lua. Most newcomers settle for 'polling'
an input in the PLC script. The SigLib{} approach is FAR more elegant.
I too use Mach4Hobby but am not aware that MachIndustrial has any extra features related to this thread. Although I do
now recall that Mach4Industrial does make use of some of the scr.********* functions for a specific editing purpose....
although the details escape me. That's the good thing about Alzhiemer's...your always meeting some new!
haha
yeah but its impossible until it works
would you be so kind to explain what you meant by :
"..not withstanding the the scr.********* functions
can do the job. That is Smurph's recommendation anyway."
does that mean if you don't understand you shouldn't mess with it?
whats the danger in using the scr*** table directly ?
do you mean an API or Mach variable being "exposed" as in being readily available/ easy to find/ apparent ?
Thanks for the kind words, but to be perfectly honest I'm far from knowing whats elegant and have zero programming style ;)
only the need to make it work, preferably efficiently , and well not break anything , can only hope i guess
I have read somewhere (might have even been a manual :o ) about "if statements slowing down the plc script and
the SigLib{} approach is the better answer, if i make lots of functions in the SigLib{} will that mess things up too? any limits there ?
surprising the person who replied to my message is local
also thanks for the link theres some great info there
no idea what a Enums is
cheers
Amyl
No, there is no danger per se in using the functions but rather there are better ways (normally) to do the same
thing.
As an example, you will no doubt have seen in the Enums and Pound variable lists the specific location/name of
the variable containing the current axis positions. You could read that memory location and get the data. However the
correct way to do so is with the mcAxisGetMachinePos() API. No doubt internal to Mach the API function reads and
returns the same Pound variable. If however the location of that variable changes, say in a more recent build, the code that
you used to read the data direct is now broken whereas the API would still work given that the API would be self consistent
with the new build.
The API mcAxisGetMachinePos() is a function that is 'exposed' so that a user might use it rather than the more direct method.
The same applies with the scr.********* functions. The manipulation of screen elements can be done with them directly but
preference is given to the APIs which 'expose' the same functionality.
Does that mean that the APIs are easy to find? Well they are documented, mostly, and mostly up to date, but they are
documented. It is true there are hundreds of APIs and it takes a lot of learning to be able to recognize and use them at will,
but they are not hidden.
No, not really, any function or code you put in the SigLib{} table will only ever be executed IF the entry
matches the variable 'sig'. Consequently all those extra funtions add zero processing overhead beyond the
entry matching test. It is indeed this feature that makes the SigLib{} such an elegant solution.
An Enum is short for 'enumerator'. For example mc.mcISIG_INPUT4 is actually a number, in fact the number 3, being
the (0, 1, 2) 3rd input. Much easier for humans to remember ISIG_INPUT4 than a plain old '3'. When the code is
compiled the compiler will substitute the number for the Enum, but that detail is not apparent to us for all its importance
to the computer running the code.
Should I assume you are in Canterbury somewhere? I used to live in Akaroa and had done for many years but have
shifted recently to Selwyn Huts on the shore of Lake Elesmere.
with the new build
I think i understand what you mean, using the API in a sense gives you stronger code less chance of breaking links after updates and with different
system configurations?
Feeling like a bit of a greenhorn with this one, should know this abbreviation
nice simple explanation !
haha no i meant nationally local, grew up in the Coromandel
beautiful down were you are, watch out for flooding
sorry if going off topic with this thread
thanks for all you help
