Mach Discussion => General Mach Discussion => Topic started by: doy on March 17, 2020, 03:58:28 AM
Title: How to use MODBUS RTU in MACRO
Post by: doy on March 17, 2020, 03:58:28 AM
Hello!
The source is:
rem M403 modebus test
Dim a1,a2,a3
'a1 = FillFromInput(1,1020, 2)
a1 = FillFromHolding(1,1020,8)
a2 = GetModWord(0)
a3 = GetInput(0)
Message "M403 Test End! = " &  GetUserDRO(1000) & " , " & a1  & " , " & a2  & " , " & a3
result
[ M403 Test End! = 1691574, -1 , -1 , 0 ]
The '1691574' value obtained from GetUserDRO (1000) is the result of normal communication in the brain.
Manual instructions should be 1. However, -1 is output.
I would appreciate it if you let me know what needs to be fixed in the above line.
