Mach Discussion => General Mach Discussion => Topic started by: PeteG on March 07, 2020, 12:01:13 PM
Hi
I have a home-made CNC machine – surprisingly accurate – but it doesn’t have an auto tool changer. So far, I have been setting the Z height between different tools using the ‘bit of paper’ method, then resetting Z zero in Mach 3.
This works well enough for my purposes, but I felt that there has to be a more sophisticated way. So I tied into my emergency stop circuit and with a connection to the cutter and another to a 0.0015” feeler gauge. I can lower the Z manually and the machine stops instantly when the cutter touches the gauge then I zero Z. But 0.0015 is a bit flimsy and I want to use something more rigid.
I have a piece of Aluminium which is 1.77mm thick. How can I use this to set Z zero?
That is no the correct way. When your machine Estops it attempts to stop instantly and it will lose steps and therefore lose
its 'reference' or 'home'.
There is a Gcode instruction especially for 'probing' called G31. for example:
G31 Z-1 F10
It is assumed that the tip of the tool is say 1/4 inch (approx.) above the feeler gauge/touch plate. The Z axis will descend
towards Z=-1 inch at 10 inches per minute UNTIL it detects a probe strike event on Machs Probe input, at which point it will
use max deceleration to stop. At that point you can use the Z axis DRO to set your Z offset.
Thanks Craig
