Mach Discussion => General Mach Discussion => Topic started by: kvid on February 27, 2020, 11:12:58 AM
Title: Cutter compensation not working (Fusion 360 and Mach3)
Post by: kvid on February 27, 2020, 11:12:58 AM
I have tried to implement cutter compensation for a while but never had any luck.
Whatever I do I always get some errors in Mach3.
I made a short recording that goes trough programming a part and importing it into Mach3. I would appreaciate any tips and suggestions.
https://youtu.be/3ZeYL-pW3V8
I attached the g-code and the fusion archive file.
Title: Re: Cutter compensation not working (Fusion 360 and Mach3)
Post by: Graham Waterworth on February 28, 2020, 09:00:02 AM
Mach3 needs a lead in and lead out with a line and radius the rad must be tool rad plus a bit and line length has to be tool rad plus a bit so if using a 10mm dia end mill lead in line could be 6mm and rad 6mm then all should be good.
