Mach Discussion => General Mach Discussion => Topic started by: battlem on February 09, 2020, 12:41:37 AM
Title: brand new cnc user.: E-stop won't stop blinking
Post by: battlem on February 09, 2020, 12:41:37 AM
Hello, I've tried for weeks to set my machine up. i have a chinazone usb cnc 6030 5 axis mill. i installed the mach3 software from the artsoft website. I've been searching the web for the proper setup for my machine but I'm lost. i can move the machine via keyboard inputs if i manually hold the emergency button on the actual router and simultaneously press the reset button in mach 3. i don't have 3 hands! i need to figure this out. I'm assuming the problem is within my configuration but I've run a few different examples I've seen online and nothing works. when I press the reset button the program says "usb mach connected" the switches back to "emergency button pressed"
Title: Re: brand new cnc user.: E-stop won't stop blinking
Post by: battlem on February 09, 2020, 01:41:09 AM
figured it out. "ports and pins>input signals>estop> click active low
Post by: Tweakie.CNC on February 09, 2020, 02:37:06 AM
Hi Battlem,
Welcome.
Looks like you have successfully started out on the Mach3 learning process  ;)
