Third party software and hardware support forums. => CS-Lab => Topic started by: BGelektronika on February 04, 2020, 09:52:56 AM
I have problem with inputs on CSMIO/ip-s module. Problem is that from time to time it doesn't get input. LED on CSMIO controller comes on, but if we look the same time on Mach3 plugin control corresponding input led doesn't come on. So when program wait for dedicated input it doesn't get it. In my situation this is when machine waits from Bar feeder Start signal, that it could start cycle again. Because of that machine is stalling all the time.
I try on other inputs, negative and positive triggering.... always the same result. It can do 10 cycles or just one or two, before it stops, and like this all day long...
I kindly ask for any inputs, coz I'm out of idea what else to do.
Whole retrofit end up perfectly now only this input problem prevent machine from running.
Thank you
Gasper
This thread also refers; https://www.machsupport.com/forum/index.php?topic=42445.msg276042#msg276042
BTW. witch Version of Mach3 are you running?
I'm running 3.043.066 version
try to run 062 for example from here:
https://warp9td.com/files/Software/Mach3/Mach3Version3.043_2018.exe
i run 043.022 because it was recomended by CSLAB.
I'll test it today and let you know result.
Thank you
All I can say is THANK YOU, THANK YOU, THANK YOU!
I installed 062 Mach version, and machine is working 6 hour now without stopping. Before it would stop 100 times at least.
I wills till have some question how to setup servo driven live tools in mach, but I'll leave it run like this some time, and then try to make live tools work.
Thank you again
Best regards
Gasper
