Mach Discussion => Mach4 General Discussion => Topic started by: ljthomps on January 21, 2020, 01:48:20 PM
Title: Machine does not respond when I hit "Go Home"
Post by: ljthomps on January 21, 2020, 01:48:20 PM
I believe this is a common issue but I have not found the answer to fix it.  When I press "Go Home" my machine does not move.  I can manually jog to home position just fine.
Title: Re: Machine does not respond when I hit "Go Home"
Post by: mark4 on January 21, 2020, 10:09:39 PM
Hello
Have you looked at the history bar across the bottom of the screen. It likely will tell you why it wont go home. Have you homed the machine first?
