Mach Discussion => Mach4 General Discussion => Topic started by: isn on January 20, 2020, 12:26:33 AM
Title: Mach4 Plasma move Z+ after cut
Post by: isn on January 20, 2020, 12:26:33 AM
Hello,
Is there a possibility that the Z axis moves up to a certain value after cutting a contour (eg + 50mm). To be at a sufficient distance from the sheet metal so as not to get caught anywhere. Could you program that into the M5 macro and if so how?
Thank you so much
Title: Re: Mach4 Plasma move Z+ after cut
Post by: Johnny Storm on June 07, 2020, 01:06:40 AM
Yes, you can do it by adding some lines of G-code in the M5 marco or whatever macro you use to turn off your torch. I doo this in Mach3 some time before and I think it works too in Mach4.
Simply add a g-code line to tell Z rise some units, for example 100mm or whatever you want. You can create a new DRO for this propuse too for make quick changes on the fly.
Hope this helps.
