Mach Discussion => Mach4 General Discussion => Topic started by: KatzYaakov on January 13, 2020, 06:08:27 PM
i use the mctoolgetdata from the lua
but when i try from api cant get any respone
i need the tool hight from the tool table
i use:
[DllImport(@"C:\Mach4Hobby\Mach4IPC.dll", CallingConvention = CallingConvention.StdCall)]
[return: MarshalAs(UnmanagedType.I4)]
public static extern int mcToolGetData(
[param: MarshalAs(UnmanagedType.I4)] int mInst,
[param: MarshalAs(UnmanagedType.LPStr)] string path,
[param: MarshalAs(UnmanagedType.I4)] int tollNum,
[param: MarshalAs(UnmanagedType.R8), In(), Out()] ref double ret);
and the function:
double hreg = 0;
int debug = mcToolGetData(0, "mc.MTOOL_MILL_HEIGHT", toolNum , ref hreg);
i also try the type as int and i try all numbers from 0-20 same no any logical return
thanks
The second argument isn't a string. It is an integer. Also, you will get a response from the API in the return code. Either that or it will crash from a bad API call. Here is the proper description of the API call:
[DllImport("Mach4Core.dll", CallingConvention = CallingConvention.StdCall)]
[param: MarshalAs(UnmanagedType.I4)] int Type,
[param: MarshalAs(UnmanagedType.I4)] int toolnum,
[param: MarshalAs(UnmanagedType.R8), In(), Out()] ref double value);
double height = 0.0;
int toolnum = 1;
int debug = mcToolGetData(0, MTOOL_MILL_HEIGHT, toolNum, height);
MTOOL_MILL_HEIGHT is a constant that resolves to 11000.
All of this is in our SDK and this is FAR beyond the scope of this forum. Unfortunately, you need to sign a nondisclosure agreement to gain access to the SDK. Contact Todd Monto at our office to get that started.
Steve
Thks alot
Do you mean i need put 11000 in the type ?
Ill contact tod tomarow thsnks alot
Yes. 11000 is the base number for the system variables where the tool information is stored. We use a Funuc tool offset memory type C layout. 11000 + tool is the location in the system variables. You could also use:
mcCntlGetPoundVar(inst, 11000 + tool, val); // This really should be called mcCntlGetSystemVar()
This means that tool height information is also available to G code. :)
Here is a handy dandy system variable memory layout chart for future reference: http://www.machinetoolhelp.com/Applications/macro/system_variables.html (http://www.machinetoolhelp.com/Applications/macro/system_variables.html)
Steve
