Mach Discussion => General Mach Discussion => Topic started by: PeteG on December 21, 2019, 06:15:20 AM
Where can I find G Code examples? e.g. interpolation of a 6mm cutter to cut a 10mm hole.
I haven't done programming for a while and that was VB, but when I was doing it I found the best way for me to learn was to download a code snippet then read it, make changes etc... and see what worked.
Hi Peter,
I think the best and easiest way is to use a CAD/CAM software to draw your part (or import the .dxf / drawing file) then it can create the Gcode for you automatically applying the tool radius and offsets, etc. Actually writing the Gcode by hand seems a bit outdated nowadays.
One of the most popular range of CAD/CAM programs is made by Vectric; https://www.vectric.com/ (for what it does it is worth every penny).
There are also many FREE softwares, one I use a lot is F-Engrave; https://www.scorchworks.com/Fengrave/fengrave.html
Perhaps Google free CAD/CAM software.
There are MANY ways to do this . Here is just one way.
G0 X0 Y0 Z0 (Centerpoint of hole)
( first pass of depth)
G1 Z-1 F10 (lower Z in center of hole)
G1 X2 F10 (move to Radius of hole)
G2 X2 Y0 I-2 J0 F10 ( Cut circle at 5mm { 3mm tool and 2 mm offset =5mm radius} radius from centerpoint)
G0 X0Y0 (return to centerpoint)
(2nd pass of depth)
G1 Z-2 F10
G1 X2 F10
G2 X2 Y0 I-2 J0 F10
G0 X0Y0
M30
It is always a good point to learn Gcode IF your machine uses it to control motion.
Hope that helps (;-) TP
Thanks, I will try this.
A weird thing happened today. I used the code and experimented with it by changing some parameters and it was working well, but suddenly it didn't work. I had run the code 20 or so times, then when it got to the line G1 Z-1 F10 (move to radius of hole) it stopped and would not go to the next line, even though I had not changed anything on that line, and it had been working fine.
I checked some other files with similar Z and X movements and they all worked.
Any ideas as to why this happened?
Best regards
Peter
Best regards
Peter
May be a typo, you do not have an X or Y direction, you have it Feeding down to Z-1 and that is it (no feeding on the X/Y plane)
Hi Guntruck 1776
Thanks for the reply, this was the code supplied to me by BR549:
(2nd pass of depth)
G1 Z-2 F10
G1 X2 F10
G2 X2 Y0 I-2 J0 F10
G0 X0Y0
M30
This was working fine with me changing various values to see what happened - I was trying to cut a 10mm hole with a 6MM cutter - with no success (I am new to this)
I changed the feed rate on this line to F20:
It was after I changed it back to F10 that the issue occurred even though the G1 X2 F10 line hadn't been changed in any way.
I went back to the original file and the same problem occurred, yet other files with similar Z & X movements are working OK
Like I said, I am new to this, so forgive any glaring ignorance on my part.
Cheers and happy new year
Peter
DID you happen to interject a G90 or G91 into teh mix ? That code would have been for G90 code (absolute). Look on teh status line and see what is set G90 or G91.
G90 is absolute mode and G91 is incremental mode.
In G90 mode say you have
G1 X1.0;
Y1.0;
X2.0;
Y2.0;
You are now 2.0 in the X from where you started and 2.0 in the Y from where you started.
In G91 mode, say you have
G1 X1.0;
Y1.0;
X2.0;
Y2.0;
You are now 3.0 in the X from where you started and 3.0 in the Y from where you started.
That would cause a problem or a crash, I personally have never used G91
Hi Peter,
Hi Tweakie
I took your advice and purchased Vcarve, it's very good isn't it. You are quite right about manual coding being a bit too old school; my first project was cutting foam to hold a Shure IEM beltpack - I work in live music and AV production. The code for what is essentially a 70 x 88 mm hole with a few other cutouts was over 1000 lines of Gcode!
Peter
Hi Peter,
I am pleased to hear you are on your way. ;)
