Mach Discussion => Mach4 General Discussion => Topic started by: Frederic1231 on December 11, 2019, 04:21:47 PM
I have bought Mach 4 last week as an upgrade for Mach3.
I have a Plasma table with PoKeys57CNC and a PlasmaSense THC unit. I am using a Floating Head configuration.
I am using the Plasma Screen and I got the THC working but sometimes while Probing it stops the cycle.
Macro Alarm: 3 The Probe did not strike during our M3 touch move.
But the Probe signal is activ if I look at the diagnostic page.
This problem randomly occurs.
Any clue?
And my value in the dros of the THC settings screen are changing every time I restart Mach 4.
You are either running out of travel (need to make the max probe distance larger) or have a noisy/bouncy input signal. Lots of post on this forum on how to troubleshoot and fix noisy/bouncy inputs. This one good example.......... https://www.machsupport.com/forum/index.php?topic=42086.msg274439#msg274439
The values in the DROs are changing because your machine units are mm or the Gcode your running is in mm mode. This has been fixed but not in a build yet. It should make it into the next build.
My max Probe travel is at 100mm and my min max THC 100 and - 100 it is more then enough.
I have no soft limits enabled.
The problem only occurs on the m3 Macro not in other Z Probe Funktions.
The I use shielded and grounded wires.
The PoKeys57CNC has some input filtering built in. And I played with the software filtering as well.
I am having this same issue with Mach4 Plasma and Pokeys57CNC. If I type M3 into the MDI and press start it will work sometimes, and other times I get the error "MACRO ALARM; 3 The probe did not strike during our M3 touch move.". If I use G31z-3 in MDI the probe works without an issue. I've tried installing an RC filter, but that didn't seem to help.
I attached a log of my probe testing with the Plasma torch turned off. The first and the third probe were successful, the second one shows the error.
i use also pokeys for woodworking cnc ,we use alot with probe,only with G31
never have problem,only with travel limit,so we add in the begin of the M function of the tool hight detect,disable the software limit
and at the end of the m function enable
Did you ever find a solution to this problem ?
I start playing few days now with my plasma and HTC, i have Pokeys57 and Plasmasens. Few tries i make, when i had the ohmic sensor on from Mach4 module i did get random times macro alarm 3. I turned off ohmic sensor and add probe move to my post processor, for now i don't have this error.
I think thats what Im going to do, i will use the Mach3 post processor in sheetcam . This seems to work a lot better.
Can I also ask what settings you have in Mach4 for you THC anti dive etc ?
Anti dive for now i have it off, the rest depends on your plasma cutter. I have a Chinese HF plasma with a lot of modifications on electronics to work, my settings will not work on you.
How have you turned anti dive off ? I`m struggling to understand what values to use for the adjust rate
You use Mach4 or Mach3? For mach4 you go to configure/plugins/regfile and there are all the options for THC and more, you find the nf/thc/AntiDiveState and change it to 0 so it be disabled.
Adjust rate is the % of the feedrate you want the TCH to make corrections on Z Axis. If your Z axis velocity is 2000mm/min and you put 10% adjust rate then your THC will correct with 200mm/min.
Are more options but if you use Mach3 aren't for you and better ask Mach3 topics for help.
Thanks for the explanation, I use Mach4 but notice the Regfile doesnt match what I have set in the GUI ? in fact its in Imperial and not Metric I will have to do some experimenting.
Check this nf/thc/DeadBandWidth default is 5, if measured voltage is -/+5V then the THC is disabled. I have it to 1 but my electronics measure very low voltage 0-5V.
Yes the default values is inches but Mach4 not understand metric/inches, just put the values you want.
Great thanks for the help, I will be doing more testing later today.
Hello I’m really struggling with my pokey 57 and the plasma sense thc I can’t get it to work if I do a test run plasma cutter on it arc but won’t read out the voltage someone any idea
You have to set the property of the Actual Voltage DRO to the Pokeys PlasmaSens HV register.
