Third party software and hardware support forums. => CS-Lab => Topic started by: Aral on October 23, 2019, 04:28:09 AM
Hi
I connected the 5v TTL input of the opt laser on the analog 0 output in the controller, and the other TTL input of the laser to digital output 2 of the controller. I can switch the digital pin 2 with the M62/63 commands. But then the laser is switch on on full power. So for cutting it is fine.
Now I am battling to get the PWM working for engraving. I can not get the spindle analog value to work. I went through all the manuals and settings and I think I'm missing something. So now I want to try something different. The idea is to make my own custom mcodes to set the analog 0 value directly on and off in the macro's, and the I can write my own post processors for the values. But now I am over my head with lua.
I emailed the support at Cslabs but either they do not understand English or do not want to help.
Can somebody maybe help me with the code to set the analog 0 value in the register.
Johan
Hi Johan,
I am not sure you are going about this the right way. A TTL input is digital and only responds to two distinct states – High or Low (excluding the High Z of tri state logic) so connecting it to an analogue output will only produce ON at full power or OFF.
Ideally, to control a laser with adjustable output power you need to gate the digital PWM signal with the M62/M63 commands. This gives laser ON / OFF at the set PWM value.
There are a number of different ways to achieve this but my best (easiest) solution is described in this thread; https://www.machsupport.com/forum/index.php?topic=12444.msg265104#msg265104
(For Mach3, read Mach4 and for M11/M10 read M62/M63)
Hope this helps.
I made this video a few years back (before the M62/M63 commands had been added to Mach4) when I gated the PWM with The A axis Direction signal.
The toolpath alternates between Cut and Engrave as the PWM is altered and it serves to illustrate the gating principle I have described.
https://www.youtube.com/watch?v=8fUg6ebWut0&feature=youtu.be
Hi Tweakie
Thanks for the speedy reply. The controller's analog output is 0 to 10V PWM, and the digital output is 24V. The laser have 2 inputs. Input one is labeled 5V TTL and input two is just labeled TTL and that one can use PWM to 24V. On the 5V input I connected a 4K2 resistor. That is the only two inputs on the laser. On another controller output I connected a solid state relay for the power supply, and is currently connected on the flood output. If i switch the laser's power supply on it takes about 3 seconds to stabilize. So I cannot use it to switch the laser on with the long delay. If I switch the power supply manually and I use the M62/63 P1 commands to activate the laser everything works perfectly but I can only cut. I know there must be a way to manually set the analog register's value in a M command but I am running in circles. I tried the following code but now I'm stuck.
function M200()
local hreg = mc.mcRegGetHandle(inst, "CSMIO-IP/Analog Output 0");
regvalue = 5;
mc.mcRegSetValue(hreg, regvalue)
end
if(mc.mcInEditor() == 1) then
-- If you are in the mcLua editor, this will cause your script to execute if you Run or Debug
-- Make sure your Capitalization and numbers match that of the function you are calling
M200()
end
Any thoughts?
Johan
Hi Johan,
Did you managed to get the laser working?
Hi
Yes, currently I am using a CNC adapter with the laser. The 0 to 10v analog output go straight into the adapter for the raster engraving. For vector engraving output 0 of the CSMIO go through a variable resistor to the 0 to 5 volt input of the adaptor. Then I change the intensity of the laser beam manually with the pot and it work nice for me. A volt meter is connected to the 0 to 5 volt input so I can adjust the intensity precise.
