Mach Discussion => General Mach Discussion => Topic started by: Shaom on September 02, 2019, 10:27:08 AM
Title: Mach3 Auto Calculator decimal problem
Post by: Shaom on September 02, 2019, 10:27:08 AM
Hi!
I have a problem with auto calculator and decimal values on wizards.
It only accepts integer value and doesn't accept numbers after the decimal point.
For example - i want to put 2.33 - auto calculator stops in 2.
When i put numbers with usb keyboard - i can do it without any problem.
Thanks for Help!
Title: Re: Mach3 Auto Calculator decimal problem
Post by: Klaus1311 on September 02, 2019, 01:56:10 PM
Hi Shaom
one reason could be your used regional settings. Perhaps you try a region which uses  a dot "." as separator (e.g. US).
Klaus
Post by: Shaom on September 03, 2019, 01:24:53 AM
Great advise! Its working now :)
Thank You :)
