G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: adprinter on August 13, 2019, 08:18:38 PM
Title: Home command
Post by: adprinter on August 13, 2019, 08:18:38 PM
I am experiencing problems with my machine. It seems that the X axis is losing steps (or some other problem). What happens, is that the X axis will get progressively off in the + direction during the carving process. I am not very fluent with G code, but was wondering if it would be possible to enter a Macro command within the G code, which would re-home the machine between each pass, then continue where it left off at. If so, what is the correct G code, or macro I would need to enter? What I am referring to, in particular, is to invoke the same macro command that is built in to the 2010 Screen set. Please HELP!
Title: Re: Home command
Post by: joeaverage on August 14, 2019, 09:08:28 AM
yes you probably could write some code that re-homes your machine but the simple expedient is to fix the
loss of steps.
